TwinTurbo.NET: Nissan 300ZX forum - Wiring a electronic boost gauge, need to connect to a
Subject Wiring a electronic boost gauge, need to connect to a
Posted by whip on February 21, 2011 at 10:33 PM
  This message has been viewed 228 times.
Message switched 12v source that does not break voltage during engine starting/cranking. The boost gauge has an auto zero function, basically it takes a pressure reading during startup for varying altitudes and it will give innacurate readings if the voltage is broken during start up. Been so long since I started the car that im drawing a blank here, pretty sure the stereo cuts out during cranking. Ill be using the clock harness for the illumination wiring and ground, but not sure if breaks voltage during starting.
TT Conversion/major restoration in progress:
